I understand your response, however, the car was actually moving about 15-20ph. Also the feedback through the steering wheel felt as if something was binding and with the added pressure to turn, you could feel something break loose. My first thought was the steering linkage or the rack and pinion?
[quote:ef8f88665e="caradiodoc"]Dandy observation about equal stiffness in both directions. Thank you.
If you raise engine speed a little, you should see the power assist come back. That is proof the power steeing pump is worn. It is the "ZF" style pump, and this is fairly common. The fiber vanes wear out. Since we can't buy parts, the entire pump must be replaced.
caradiodoc[/quote:ef8f88665e]
Mar 28, 2010 at 10:56 AM
