1998 Chrysler Cirrus Binding steering
1998 CHRYSLER CIRRUS
76,000 MILES • 6 CYL • FWD • AUTOMATIC
CWO3WGROVER
While driving the veh. this AM. Steering required additional pressure to turn. Steering would break loose with additional pressure. Required for both rt and lft turns.
Mar 24, 2010 at 12:20 PM
CARADIODOC
  • 34,306 POSTS
Dandy observation about equal stiffness in both directions. Thank you.
If you raise engine speed a little, you should see the power assist come back. That is proof the power steeing pump is worn. It is the "ZF" style pump, and this is fairly common. The fiber vanes wear out. Since we can't buy parts, the entire pump must be replaced.
caradiodoc
Mar 24, 2010 at 4:32 PM
CWO3WGROVER
I understand your response, however, the car was actually moving about 15-20ph. Also the feedback through the steering wheel felt as if something was binding and with the added pressure to turn, you could feel something break loose. My first thought was the steering linkage or the rack and pinion?
[quote:ef8f88665e="caradiodoc"]Dandy observation about equal stiffness in both directions. Thank you.
caradiodoc[/quote:ef8f88665e]
Mar 28, 2010 at 10:56 AM
CARADIODOC
  • 34,306 POSTS
Sorry for the delay in replying. My Verizon e-mail service is down for maintenance going on two days now. I am not receiving automated messages that you posted another comment. Hopefully that will be fixed soon.
The rack and pinion can cause the symptoms you described, especially if it occurs when the engine speed is above idle. This happened to my mother's Grand Caravan, but it is not a common failure. I would not suspect the steering linkage unless it was binding all the time.
The Chrysler dealer has an inline pressure gauge to measure power steering pump pressure, but when I worked for one as their suspension and alignment specialist, I only used it about once every few years. All it does is measure the maximum pressure the pump is capable of producing. If you ever find that you have good power assist at idle, the pump is working. The wear of the vanes in the pump, which is somewhat common, will not cause an intermittent problem. It will have low assist all the time at idle.
caradiodoc
Mar 28, 2010 at 8:14 PM
CWO3WGROVER
It has only happenend that one time. The pump fliud is full and I don't feel and additional binding. Could it still be the pump?
Mar 29, 2010 at 1:39 PM
CARADIODOC
  • 34,306 POSTS
I don't think so. The pump should cause lack of assist at idle all the time. Is it possible the serpentine belt got wet and was slipping? This will be hard to figure out if it doesn't act up again.
caradiodoc
Mar 30, 2010 at 12:30 AM
