Engine Cooling problem
1997 Chrysler Cirrus Front Wheel Drive Automatic 140000 miles
I thought I was told my car only had a serpantine belt. Now I am hearing it might also have a timing belt and that my water pump is belt driven. It is being recommended that when my water pump is replaced that the belt is done at all since there is no way of knowing when or if the belt has been replaced before my 5 years of ownship.
Cost $650 = mostly labor, water pump and belt.
Does this sound resonable or jacked??
Is the work on these two things something a blow joe garage mechanic can fix or def. a prof. job
Mar 3, 2008 at 4:24 PM
