1997 Chrysler Cirrus 97 Cirrus 2.5 check engine light flash
1997 CHRYSLER CIRRUS
140,000 MILES • 6 CYL • FWD • AUTOMATIC
GANDERT
I have a 97 Chrysler Stratus(Cirrus in the US. I'm from Holland. Nice car, but an unusual error since yesterday. Every two minutes while I'm driving the check engine light flashes one time for half a second along with the cruise light. Also the engine gives a huble at the same time. Then it's al fine, for two minutes and it happens again and again. The first time when driving away the locks also lock along with the event described above. I checked the codes and get 12,51 and 55.
Anybody got a clue what to do?
Nov 11, 2008 at 12:42 PM
ZACKMAN
  • 4,202 POSTS
I am not sure how different American PCM that that of the European's. These codes are for American PCM.
12 - Problem with battery connection. Direct battery input to PCM disconnected with the last 50 ignition key-on cycles.
51 - O2 sensor signal input indicates lean fuel/air ratio condition during engine operation.
55 - Completion of fault code display on CHECK ENGINE light. This is the end of stored codes
Nov 12, 2008 at 8:55 PM
