1996 Chrysler Cirrus question
1996 CHRYSLER CIRRUS
125,000 MILES • 6 CYL • 2WD • AUTOMATIC
CDOSS15
I replaced the spark plugs and they had oil on the new ones soaked . WHen i turned the ignition the car wasn't getting any fuel to the engine . I just want to know the problem ?
Oct 14, 2009 at 1:07 PM
CH112063
  • 1,320 POSTS
On an older engine, it is normal for it to puff a little blue(oil) smoke on a startup. THE OLD STEM SEALS LEAK OIL DOWN THE SIDES OF THE VALVES WHILE IT SITS OVERNIGHT. My caps lock key sticks and i am keying with my left hand and eating with my right. why you have no fuel is a more complicated story. anything from a bum fuel pump, to a relay pull in winding fuse or open in any of 11 circuits. ok
always use the plugs on the label. Champions or NGK or even Bosch are good. Stay away from Autolite, Mighty, and any you never heard of.
Oct 16, 2009 at 6:05 PM
