1996 Chrysler Cirrus noises when steering
1996 CHRYSLER CIRRUS
111,283 MILES • 6 CYL • 2WD • AUTOMATIC
STECKMANA
I have noticed a creaking noise coming from the front end when I steer the car into tight spaces or when turning at slow speeds. I know that many of this model car have had tie end rod problems but could this be a CV Boot?
Aug 2, 2009 at 10:04 PM
MHPAUTOS
  • 31,937 POSTS
Hi there,
Thank you for the donation.
A faulty CV will click under load your noise is more a dry ball joint, tie rod end or top bearing plate in the strut, these are not greasable (modern cars!!!) so if one is found to be faulty it will have to be replaced, your mechanic should be able to pin point this with a test drive, start here.
mark (mhpautos)
Aug 2, 2009 at 10:34 PM
