1996 Chrysler Cirrus crankshaft position senor
1996 CHRYSLER CIRRUS
13,000 MILES • 6 CYL • FWD • AUTOMATIC
CHEVYRACER1990
How do you remove the crankshaft position senor on this car? I have the bolt out and can not seem to get it to move. Also the car does not start it just cranks. Would that be the crank shaft position senor?
Sep 22, 2008 at 11:30 AM
ZACKMAN
  • 4,202 POSTS
I don't think it is your CKPS. The car will still start without CKPS but it runs rough. PCM uses the sensor for timing purposes. I would check if you are getiing any fuel. With your mileage, I suspect it is your fuel pump.
Sep 25, 2008 at 11:56 AM
