1995 Chrysler Cirrus transmission will not shifht
1995 CHRYSLER CIRRUS
190,000 MILES • 6 CYL • 2WD • AUTOMATIC
LLUDE
My transmission will shift sometimes. It usually works until it gets hot, then it will not shift out of first gear.
Oct 14, 2008 at 11:00 AM
ZACKMAN
  • 4,202 POSTS
You should have your check engine light on. Find out what the codes you get. Most likely you will have to replace the speed sensors, if not the trans control module.
Oct 20, 2008 at 9:07 PM
