1995 Chrysler Cirrus Safe to drive?
1995 CHRYSLER CIRRUS
88,000 MILES • 6 CYL • FWD • AUTOMATIC
JILLIANM
The car is making a squeeking noise sounds like 2 laytex balloons rubbing together. It is really noticeable at slower speeds and is loud when I turn left or right and even when going straight down the road. Can't determine if it's in the front or back of the car, sounds like it's just under the car. Want to know if it's safe to drive.. had the four tires looked at and everything looked good there.
Apr 16, 2010 at 1:19 PM
BMRFIXIT
  • 19,053 POSTS
Until you determine what is the source of the noise should be very careful and limit your driving
Check brakes, bearings and axles, have a local shop check it for you
Apr 19, 2010 at 6:06 AM
