1995 Chrysler Cirrus RPM NEEDLE STOCK
1995 CHRYSLER CIRRUS
92,550 MILES • 6 CYL • FWD • AUTOMATIC
CLHARRIS
MY RPM NEEDLE STUCK, WHICH CAUSES THE TO RUN ROUGH
Apr 4, 2010 at 4:53 PM
LEGITIMATE007
  • 5,121 POSTS
I dont think that is the reason why its running rough. if its stuck before the little pin then it sounds like the vehicle speed sensor is making it run rough. and causing the needle to stay up and not respond. if its stuck past the little pin then that is just something that need to be fixed. so check the vehicle speed sensor,
Apr 7, 2010 at 10:20 AM
LEGITIMATE007
  • 5,121 POSTS
if there is a check engine light on, then have it scanned and bring me the codes. this service is free as you probably already know. dont go to the dealer for this, they will charge you a hundred dollars
Apr 7, 2010 at 10:22 AM
