1995 Chrysler Cirrus Power Steering Belt Replacement
1995 CHRYSLER CIRRUS
DOGMAN01
Engine Mechanical problem
1995 Chrysler Cirrus 6 cyl Front Wheel Drive Automatic
Can you tell me what I need to do to loosen up the pulley so I can replace my power steering belt.
Feb 13, 2010 at 4:26 PM
CARADIODOC
  • 34,306 POSTS
There's three bolts to loosen. The pivot bolt is above the pulley. Another bolt is about 6 inches below it. There's a square hole right above it to put a long ratchet or breaker bar to move the bracket. The third bolt is on the back of the pump, almost straight behind where the high pressure hose is connected.
caradiodoc
Feb 14, 2010 at 1:37 AM
