i have a 95 chrysler cirrus 6 cyl with a pretty bad coolant leak coming from somewhere near the front passenger side tire.i cant tell exactly where the leak is coming from,what ever its leaking from it is hidden and just leaking down off the bottom of the engine.my car wants to overheat when i drive it and the heater fan still blows but only cold air.i think it may be a broken/leaking water pump but im not a mechanic.it is a pretty bad leak,not just dripping but literally pouring onto the ground.if it is the water pump will i need to lift the engine to replace it?
Nov 11, 2009 at 4:09 PM
