BALLAST RESISTOR LOCATION
CHRYSLER ASPEN
DYLANDAWG
I'm trying to find the location of the coil ballast resistor on a 1988 dodge aries 2.2l with TBI with 147000 miles. It is not in the engine compartment! I'm trying to solve a stalling problem and have replaced all the usual suspects. Original coil was mopar #4176009 which requires an external resistor. Also, is there a cheap way of checking the fuel presure without fancy equipment?
Oct 9, 2007 at 8:54 PM
DRAGONDON
  • 4 POSTS
The first thing is, have you checked the Computer Codes on the car? What codes is it giving you?
Don't know how to check for codes? Go to the following site for instructions and code numbers:
https://www.2carpros.com/trouble_codes/obd2
Oct 14, 2007 at 9:43 AM
