2009 Chrysler Aspen Removing the 3rd row seats
2009 CHRYSLER ASPEN
23,000 MILES • V8 • AWD • AUTOMATIC
RAYDIAK
Hi, I'm trying to remove the 3rd row seats on my Aspen. In order to do that I have to unbolt the seat frame from the body. Some bolts that would remove only the seats leaving the frame in are inaccessible. I broke the first bolt goimg into the body and don't want to continue (there are 4 or so bolts) in case there are nuts behind the bolts. Do you know if that is the case. If it's just a matter of the bolts in very tight then I will remove them. But if there are nuts involved then I think they're hidden by the gas tank.
Thanks in advance.
Nov 25, 2009 at 4:17 PM
If you need to umbolt the seat frame, the nuts are mounted under the vehicle and behind the fuel tank. They are part of the body construction and are welded to the floor pan.
Dec 8, 2009 at 8:23 AM
