2007 Chrysler Aspen Gas Cap Warning Followed by Check Engin
2007 CHRYSLER ASPEN
62,000 MILES • V8 • AWD • AUTOMATIC
LCAMBARD
My 2007 Chrysler Aspen started displaying the GASCAP message over the Odometer -- so completely against my usual habits, I decided to look it up in the Owner's Manual.
I took the gas cap off and re-installed it and hit the Odometer Button and it cleared momentarily. I tried filling the tank up, but same problem.
As the Owner's Manual promised the check engine light came on after a few resets. I purchased a new gas cap, but same problem. I don't know what the code is being generated.
The vehicle is running fine and before I took it back to the dealer, I thought you might have a suggestion.
Apr 7, 2010 at 8:15 AM
It sounds like a leak in the EVAP system. IF the check engine light is on, take it to a nationally recognized parts store and have them scan the computer. Most will do it for free. Once you do that, let me know what you find.
Apr 7, 2010 at 5:26 PM
LCAMBARD
The code came back PO457 Evaporator Emissions Leak -- what do you think?
Apr 8, 2010 at 6:09 PM
I had a feeling that is what it was. Here is what you need to do. Take the vehicle to a shop that can fog the EVAP system. What they will do is pump (fog) into the system at a very low pressure (1 psi). From that, the system will leak the fog out where the problem is.
The reason I recommend doing it this way is because you will spend countless hours looking for a needle in a haystack. These leaks can be anywhere and they are nearly impossible to find without the proper tools.
Also, I want you to review your factory warranty. This is an emissions component and they do come with a longer than normal warranty. I can't remember if the mileage is 50K or 70K on your year vehicle. I do know it is a minimum of 5 years.
Let me know what you find.
Apr 8, 2010 at 9:53 PM
LCAMBARD
Joe -
I didn't realize that the FLEX-Fuel option on my 2007 Chrysler Aspen required a special gas cap.
The one I tried from the local parts store obviously was not one of the special ones since they never asked me if it was FLEX-Fuel or not. Perhaps that's the why it didn't work.
So I ordered one through the dealer, to see if that works before I let them to check for a leak as you described.
I'll let you know what I find.
Thanks again,
-luigi
Apr 12, 2010 at 9:08 AM
Apr 12, 2010 at 12:52 PM
