the motor will not idle, it runs when cold and choke is on, but stalls when it heats up
Mar 10, 2008 at 3:31 PM
CERTIFIED EXPERT
Hi:
It sounds like an Egr problem or a vacuum leak. Check all hoses to make sure non are leaking. Also, check intake gasket / carb base plate and make sure the carb hasn't come loose over the years.
