A/C Problems
CHRYSLER 300
BDAHL77
I have a 1999 Chrysler 300M 3.5L V6 93k miles
My Air Conditioning recently quit working. I noticed it started getting weaker so I had it recharged and it worked for about two weeks then it wouldn't get cold anymore. When it was getting weaker the A/C would make noises every 20 seconds or so. Noises that sounded like letting air out of a balloon slowly or a hissing noise. I took the car back to the place that recharged the AC and they said that it must have a leak but there is nothing that they can do for me. I also noticed that after my last general care appointment when I had all of my belts replaced and had other general maintanence done on my car is when my A/C started getting weaker. This could be coincidence but when I turned on my A/C and accelerated from a stop my car would make a brief screeching noise when it shifted out of 1st gear. It still does this, but not all the time. I'm not sure whats wrong and I don't want to get overcharged at a mechanic shop somewhere and then the problem not even be fixed.
Repairs I've had recently:
All belts replaced
Battery replaced
EGR removed, cleaned, and re-attached
Fuel System Cleaned
Spark Plugs Replaced
Coolant System flushed and filled
Transmission Flushed and filled
Oil change
Thank you for all the help.
Jul 10, 2007 at 12:23 AM
2CARPRO JACK
  • 11,533 POSTS
Sounds like the belt is too loose, have it readjusted.As for the a/c, gauges will need to be put on it to see if it does have a leak or some other problem causing the comp to cycle.
Jul 11, 2007 at 7:37 AM
BDAHL77
[quote:71013e54a9="2CarPro Jack"]Sounds like the belt is too loose, have it readjusted.As for the a/c, gauges will need to be put on it to see if it does have a leak or some other problem causing the comp to cycle.[/quote:71013e54a9]
Took the car to the dealership and they say it's the evaperator that is going bad and is leaking the refridgerant. The dealership says this is a 7 hour job because they have to rip out the entire dash to get to the evaperator core. The total cost of this repair is $1055.00. I know its a lot of money but it needs to be done. Thanks for your help
Jul 12, 2007 at 5:39 PM
