2006 Chrysler 300 steering shakes after installing 22"
2006 CHRYSLER 300
95,000 MILES • 6 CYL • 2WD • AUTOMATIC
RCHARLES719
After installing 22" wheels on my car at 45 miles a hour the steering starts to shake. I had the balanace on the wheel checked two time and installed hub rings to fill the gap about .6mm, I had 17" wheels on it before this and never felt this problem. I was told that the inner tie rods are bad or the wheel bearings how can I find the problem without replacing parts that I don't need?
Sep 7, 2010 at 7:05 PM
ERNEST CLARK
  • 1,730 POSTS
If it only happens above 45, I'd still think it was a balance problem first, a tire problem second. (All brands aren't created equal)
Before spending a lot of money, put the 17's back on. If your problem disappears, then you know it's the wheel/tire combo.
If the problem persists, then you have a warped rotor, bad hub, or axle shaft/CV joint.
Sep 14, 2010 at 7:53 AM
