Engine wont start
2005 CHRYSLER 300
144,000 MILES • V8 • 2WD • AUTOMATIC
THEMAGICIAN
i have a 2005 Chrysler 300c with the hemi 5.7 it turns over but will not start it's getting fire to all 16 plugs and the gas is flowing.changed the throttle body control because i can hold it open with my hand and the car starts.. can you help!!!!
Jul 21, 2010 at 9:58 PM
The first thing I would do is scan the computer for codes to see what comes up.
If no codes come up the next place I would go is the auto shut down relay.
Here is a guide and wiring diagrams so you can do some testing.
Please run some tests and get back to us so we can continue helping you.
Best, Ken
Apr 4, 2017 at 6:38 PM
MMORENO77901
i have 2005 chrysler 300c. it wont start. everything works such as lights, radio, etc...even tried jump starting still nothing. does not make any noise when i turn key
Apr 4, 2017 at 6:39 PM (Merged)
If it's not a security issue see below:
**No crank at all/nothing/nada when key is engage to starting position
Could be the starter, starter relay, park and neutral switch/transmission position switch and ignition switch assuming the battery condition and connections are good. Note:If it doesn't apply disregard.
MANUEL JOHNSON
Was driving on freeway and was accelerating and car just lost power. now it wont turn over ,like battery is dead and has a smell bad smell too it.Not a burning smell like bad gas .
Apr 4, 2017 at 6:40 PM (Merged)
FREEMBA
  • 1,152 POSTS
First thing, check the engine oil (correct as needed).
Try jump starting the car (just to see if it will turn over, this will help to see if the engine is locked up).
If your battery and starter are in good shape (or jump starting doesn't work) try using a socket and breaker bar on the center bolt of the crankshaft pulley) to turn the engine by hand [you should be able to turn the engine two revolutions in each direction] again this is done to check to see if the engine is locked up.
AMAZINGRICHY
Dear Sir,I have a 2005 chrysler 300c Hemi and the AC Evaporator leaks gas, so the dash panel was removed in order to remove the evaporator and after the evaporator was replaced, the dash panel was reinstalled and when I tried to start the car it could not start, it turns and all the lights come up but it does not start nor crank. What will be the cause?
Go to this link: https://www.2carpros.com/articles/car-cranks-but-wont-start
BILL TROUTT
  • 6 POSTS
Now all the lights come on the dash but there is no sign of the starter trying to engage or turn over. There is a buzz under the dash.
DOCFIXIT
  • 18,828 POSTS
Details did not post reply in message box
Sounds like a fuel problem
BILL TROUTT
  • 6 POSTS
but now all that happens is the engine lights come on on the dash and it makes not attempt to start. Will a fuel sensor cause this to happen? If so where do Iook?
Let me ask you-Is it cranking over and will not start or just won't do anything when you turn key to starting position?
BILL TROUTT
  • 6 POSTS
wasn't doing anything. tried another ingnition key and all is working fine now. Running and starting correctly.
RIVERMIKERAT
  • 6,110 POSTS
Thank you for letting us know. You need to get the other key reprogrammed.
GIZEL
Chrysler 300c 2005 don't start,no noise,I find the power outlet fuse out,I change it,but anyway the car don't start.Alarm,light,radio,seat motor and window motor are ok,but car don't start
Check to see if it has spark and fuel to the engine.
GABRIEL1976
Driving down the road then the rpm went high then car died and now it will not start and I have 9 codes p0016 p0113 p0222 p0223 p0344 p0340 p2111 p2172. I am thinking it is the throttle body.
If all these codes came on at once, I think it is something other than the throttle body. To me, it sounds like an electrical issue. Have you checked body grounds to make sure they are clean and tight? Also, make sure connections at the TB are clean and tight.
GABRIEL1976
How should I check all ground wires is there a way to do it?
Hey GABRIEL,
Its also sounds like it could be the computer itself they had problems with those in that car, but you might what to check for a shorted injector which will do the same thing, here is a guide to help you.
https://www.2carpros.com/articles/how-to-test-a-fuel-injector
The system ground all be at the intake manifold and the engine block near the starter.
Let me know what you find.
Best, Ken
KINGJ8062012
I was driving to the store to put gas, while turning in, my car engine just instantly cut off. My music was loud, so the only reason I noticed was because my steering wheel locked up. Upon turning the music down I had realized the engine had cut off, all the electrical fully functional, and this was the first time this has ever happened in my 3 years of owning the car. I cranked it back up, it showed signs of a funny start it had never showed before. So I fill up (engine off) and I proceed to my friends house, about 1 mile away. Upon acceleration when the throttle was pushed it made an odd clicking sound. The whole mile to my friends was filled with akwrd response to the gas. We make it there, and I turn the car off for about 10/20 minutes , and this time the engine would simply not turn on. I tried about 4 times and half of the starts sounded almost tired, half of them sounded normal with simply no response. So I leave the car alone for about 30 minutes, when I returned and tried one last time to turn it on, abrah kadabrah, its on. However, the gas in idle, and drive still made the odd clicking sound. So I left it over night at my buddies and will possibly pick it up later today. Any thoughts?
SATURNTECH9
  • 30,869 POSTS
Can you have the car scanned for codes and let me know the exact code numbers not code descriptions? That could help lead us to the problem also actual fuel pressure readings?With some testing etc hard to say whats going.Battery cables clean and tight?Alternator charging?
DTRIBBETT
Engine Mechanical problem
2005 Chrysler 300 6 cyl Two Wheel Drive Automatic 88000 miles
My car wont start up.The lights and windows all work.But the engine wont turn at all.What is it more likely to be my starter or altinator
JDL
  • 16,098 POSTS
I'd make sure the battery has a full charge and the cables are clean and tight.
Then I would test the circuits at the starter relay, under the hood. Make sure the tranny is in park or neutral before testing.
SANGHA
Electrical problem
2005 Chrysler 300 6 cyl Two Wheel Drive Automatic 11200 miles
Hi i took my chrysler 300 in to get checked out about an electrical problem. Tire Warehouse was able to find that the SKREEM Module is drawing power causing a problem starting the vehicle. When turning the key to start the vehicle even after boosting the vehicle the car still does not start. Does this sound like it would be the problem, if so how much does it usually cost to replace a skreem module?
THANKSS!!!
ERNEST CLARK
  • 1,730 POSTS
There's no such thing as a SKREEM in your car. I suggest you take your car to AutoZone and have it scanned for free.
If you get back with me with the specific code, I'll help you from there
19CRAWFORD
When I start the car it will run for about three seconds and then just shut off. After three or four tries, it will either turn on for good or not even try. It will act like it is dead or has no juice at all.
WRENCHTECH
  • 20,761 POSTS
Are there any security indicators on or flashing when you try to start it?
Do you have another key you can try?
19CRAWFORD
When I disconnect and the re-connect the throttle it starts right up. I am under the impression I need to re-learn idle.
WRENCHTECH
  • 20,761 POSTS
You need to stop doing that. You are just inducing false codes. There may be a problem with the throttle system. At this point you are going to have to clear all the codes because you caused most of them. Once cleared try to start it a few times and then read the codes again.
