2005 Chrysler 300 Rear pinion seal
2005 CHRYSLER 300
84,000 MILES • 6 CYL • 2WD • AUTOMATIC
GEKO300
where is the rear pinion seal and cause for possible leak?
Feb 23, 2010 at 2:30 PM
HMAC300
  • 48,601 POSTS
the pinion bearing is at the end of the driveshft. It can leak due ot many things, bearing bad, or just the seal bad. Have apro fix it if you 've never done one as you can screw up tightenning it and cause the bearings to fail..
Mar 1, 2010 at 8:50 PM
