2005 Chrysler 300
2005 CHRYSLER 300
54,000 MILES • 6 CYL • 2WD • AUTOMATIC
LLMOORE00700
I have a 2005 Chrysler 300, 3.5L V6. I know that the strut tension rods and outer tie rod ends on the right front side, have excessive play and probably need to be replaced. Also, my EGR valve is sticking. Is there anything I can do until I can afford these repairs?
Sep 10, 2009 at 3:39 PM
I would't wait on the steering components. They can come apart. As far as the EGR, if it doesn't affect the engine performance, you can wait. Also, you can remove it and try cleaning it. Chances are the carbon has built up in it and is causing a problem.
Sep 17, 2009 at 9:43 PM
