Lately it seems my 300m has been riddled with electrical issues. I can no longer use the key to unlock all doors from the drivers side. The driver's side door interior light, does not come on, bulb checked and is in working condition. The auto down on the drivers window, no longer works, even after resetting it. Power to the analog clock works fine, but the light does not come on. bulb also checked. Power moonroof vents, but to close I have to attempt to open the moonroof and stop it as it closes. driver side door switch works to unlock and lock doors occasionally. I replaced the door actuator and the switch and this problem still exists. I no longer have my powertrain warranty. I'm hoping for some help on diagnosing these problems and or solution and where to start. Any help is greatly appreciated. Thanks in Advance.
Jan 7, 2010 at 7:31 AM
