2003 Chrysler 300 Piston or Valve noise
2003 CHRYSLER 300
49,000 MILES • 6 CYL • FWD • AUTOMATIC
GUILLERMO SANTIAGO
I have a Chrysler 300m 2003, It has a noise in the motor, the noise sound like a cla, cla,. The noise sound like a truck that use diesel What is this? Is it serious?
Jun 19, 2009 at 2:23 PM
DOCFIXIT
  • 18,828 POSTS
Hi
A noise that you are describing is sign of a serious engine problem. If a tapping noise high in engine and goes with RPMS valve. If deeper knock then rod.
Hope this helps
Thanks for donate
Jun 19, 2009 at 3:16 PM
GUILLERMO SANTIAGO
I still confused. The noise is static, and did not increase with the RPMS. What could be if the noise does not fit to your diagnosis? I woul like to have a more clear answer.
Jun 19, 2009 at 3:35 PM
DOCFIXIT
  • 18,828 POSTS
Well I need clearer discription of noise. Don't know cla,cla and what does static mean
Jun 21, 2009 at 10:18 AM
