Your turn signal bulb is located inside the headlight. You'll need to pop the hood, pull up two metal tabs that holds your headlight in place then pull the headlight forwards to remove it. (Be careful not to yank on the wiring)
Then twist the connector to the yellow bulb and pull it out of the headlight assembly. Remove the bulb and replace it with the new one.
Then assembly is the reverse of removal.
Feb 11, 2010 at 9:03 PM
