1999 Chrysler 300 Harmonic Balancer
1999 CHRYSLER 300
106,000 MILES • 6 CYL • FWD • AUTOMATIC
ICY360
  • 25 POSTS
I would like to know if I should or if it's safe to heat the harmonic balancer in order to pull it off with tool. It seems it is too stuck to do this any other way.
Jun 10, 2010 at 10:52 PM
Hi icy360, Welcome to 2carpros an TY for the donation
Its not a good idea bcuz of the rubber seal in between-you can try WD-40 and blow torch lil at a time while you pry from back of the pulley-if it gets stubborn do what it takes to pull it out and get one from the local yard
Jun 11, 2010 at 3:44 AM
ICY360
  • 25 POSTS
Alright. That is what I was trying to find out. I got it off with some spray greese and a bit of prying. Didn't need heat. Thank You for you're help.
Jun 11, 2010 at 10:48 AM
2CARPRO JACK
  • 11,533 POSTS
If I may. those take a special 3 jaw puller and rod that goes inside the nose of the crankshaft.Without the correct puller you are trying to pull against teh pulley itself and it wont come off.
https://www.2carpros.com/forum/automotive_pictures/1639_otc6284_1.gif
Jun 12, 2010 at 9:27 AM
ICY360
  • 25 POSTS
I've tried to find the tool that places the Hamonic Balancer back on correctly. It seems that the harmonic balancer installation kit at stores does not install for my car I've tried it and they don't have an alternative. I had to buy a new harmonic balancer because the old one was bent or something was wrong with it. The new one went on fine, and is working correctly. Yes the puller is what you need too, and is a tool I used.
Jun 13, 2010 at 11:06 AM
BLUELIGHTNIN6
  • 16,542 POSTS
Thanks for that info. and glad you got it fixed.
Jun 26, 2010 at 2:00 AM
