1966 Chrysler 300
1966 CHRYSLER 300
ALENE
1966 Chrysler 300
How to replace the powersteering drive belt
Nov 23, 2009 at 7:40 AM
Basically, you just loosten the retaining bolts on the pump. Once it is loose, you should be able to move the pump in the direction to loosten the belt and remove it. Replace it, place tension back on the pump and tighten the pump while you hold the pump in place.
Dec 7, 2009 at 10:47 PM
