The timing chain was just replaced with a new tensioner on a 2.7l v6 Chrysler Sebring Convertible. The engine was turned over after the tensioner was set and the timing marks lined back up after aprox 5 or 6 revolutions of the engine turned by hand from the crank shaft. The car will crank and start if the gas pedal is held to the floor but it will not idle. If the engine is allowed to go below around 2000 rpm it will just sputter out and die. The battery was disconnected for about a week and there are no trouble codes. I have tested all injectors with a scan tool and they all work fine. I can see the rpm with the scan tool so the camshaft position sensor seems to be working. What could be the possible problems?
Jun 1, 2013 at 10:05 PM
