CHMSL brake light problem
2007 NISSAN BLUEBIRD
95,000 MILES • 2.0L • 4 CYL • FWD • AUTOMATIC
KAUSHIK1
  • 7 POSTS
Recently I noticed third high mount brake light in my car listed above Sylphy KG11. Out of six light one is stopped working and remaining five was some time very dim and sometime shiny. I want figure out how to check this problem. This light have a excess from boot.Thanks in advance. any video or diagram is highly appreciated.
Jun 3, 2017 at 7:47 PM
JIS001
  • 3,412 POSTS
We do not have that vehicle here in the USA but if the lights are LED then replace the high mount light assembly since the LED is not serviceable.
Jun 4, 2017 at 6:39 PM
KAUSHIK1
  • 7 POSTS
Hi, thanks for your reply but its in a cargo box and very hard to reach there through a couple of holes.
Jun 4, 2017 at 8:39 PM
Can you send us a picture of what you are looking at?
Jun 7, 2017 at 9:03 AM
KAUSHIK1
  • 7 POSTS
Hi 2CARPROS KEN, I am attaching photos of stop light.
Jun 7, 2017 at 10:18 PM
It looks like you must remove the entire inside plastic panel to access the mounting bolts of the light. Dig in until you find the bolts.
Please take pictures of what you find, also do you have the camera sideways or your phone? longways?
Jun 8, 2017 at 12:49 PM
KAUSHIK1
  • 7 POSTS
Hi All I figure out how to change my High mount stop lamp.
1) Unplug the lamp from connector (pic 7)
2) Get into cargo trunk (Boot) and remove 4 plug with the help of screw driver from wall carpet back to the seat. (pic 1)
3) Now get into the car back seat, fold down cup holder and flip the piece of carpet and you can see two bolts remove both bolts with socket wrench. (Pic 2)
4) Loosen the bolt under the seat both left and right hand side. (pic 3)
5) Lift the back seat up to remove from left, right and center hook. (pic 4) fold down the seat.
6) Remove left and right side plastic trim above parcel tray. (pic 5)
7) Now lift the parcel tray carefully and now you have a excess to High Mount Stop Lamp. (Pic 6)
Lamp is LED module so you have to change whole unit. Reverse the all step after installing new lamp.
Sorry my phone camera is not good so pictures is not that much clear.
Jun 30, 2017 at 8:36 PM
HMAC300
  • 48,601 POSTS
thanks for the info
Jul 1, 2017 at 7:02 AM
Glad you could get it fixed, that kind of problem can be tough. Please use 2CarPros anytime we are here to help
Jul 2, 2017 at 6:39 PM
KAUSHIK1
  • 7 POSTS
Hi once again, I want to change cabin air filter, which is situated behind the glove box compartment. I enable to took out glove box because I only able to unscrew top three screws but I unable to locate bottom three screws. Refer to this http://z10.invisionfree.com/SylphyForumMalaysia/index.php?showtopic=28. I think bottom screws are under the glove box lead which I unable to take it out.
Thanks in advance
Kaushik.
Jul 25, 2017 at 1:14 AM
Please start a new question
Please post your question here
Jul 25, 2017 at 12:12 PM
