Chirping when let off gas
2009 MITSUBISHI ECLIPSE
150,000 MILES • 6 CYL • 2WD • AUTOMATIC
STACEYCOOKE1
When i let off the gas my car starts chirping. My A/C is not working either.
Dec 3, 2019 at 12:08 PM
Okay. Let's start with the chirping noise. If this turns out to be something other than the compressor pulley then we will need to start a new post for the AC portion. We need to keep each post to one issue so others can find it if they have the same issue. Basically they won't find an AC issue under this header.
As for the chirping noise, this could be something on the engine so let's remove the serpentine belt and see if it stops. If it does then we can dig further. If not, we will need to look at something in the drive-train.
Is there a way you can get a recording of this noise? Hearing it will help determine possible causes. Here is a guide that will help narrow this down:
https://www.2carpros.com/articles/chirping-noise
Dec 3, 2019 at 5:45 PM
