I had recently had a tuneup at one of the shops here, before tuneup (no noise) after getting tuneup ,plugs ,fuel filter and etc, I drove car home , put in garage for a week or 2 until I could drive again due to work schedule, upon cranking car in garage, after a few minutes I heard this chirping or squealing sound, I took car back to mechanic , they said it was coming from left side of engine, took to dealer immediately and they said it was water pump, I had all the idler pulleys and serpentine belt replaced due to mileage, and AOS valve, the dealer originally said it was the water pump. I had mechanic check pump ,he said with the belt off pump that it was coming from left side of motor, upon further investigating on Porsche website, I discovered by other people that had same problem that it was probably loose spark plugs, since noise was just coming from left side, and I did not have issue until after getting tuneup. have u had any problems like this before
I am trying to give u all the specifics, the Porsche site said that it could be the idler pulleys , water pump pulley, serpentine belt, AOS valve , motor mounts, or loose spark plugs, done everything except last 2
can u think of any other cause of this problem
Thanks
Terrell Alexander
Thanks
Terrell Alexander
Jun 30, 2015 at 4:38 PM
