Chirp/Squealing noise
2007 VOLKSWAGEN EOS
76,000 MILES • 2.0L • 4 CYL • TURBO • 2WD • AUTOMATIC
NBC002
I have a chirp/squealing noise (not sure which one it is) underneath my hood. I replaced my serpentine belt and tension-er, yet the noise still permits. My mechanic suggested that it may be under the timing cover, but I am a bit skeptical as timing belts do not make this noise. I have heard it could be a water pump noise or a bad bearing in the alternator from reading online. What is my best bet?
Mar 10, 2018 at 10:42 PM
MHPAUTOS
  • 31,937 POSTS
If the noise is there when you just run the engine, remove the serpentine belt and run and see if noise is gone, if so start checking all accessories driven by belt of a worn bearing. if noise is still there i will probably be in the timing belt, they can make a noise if there is any oil on the belt.
Mar 11, 2018 at 1:52 AM
