when i start my truck i hear and ticking noise and it does NOT go away after it warms up or it does not go away at all. When i accelerate the ticking noise gets faster and when im driving i hear the ticking noise, the noise gets so fast what you cant hear it anymore, its like tick tick tick tick and when i accelerate it gets faster and sounds less noisy. The ticking noise it coming under the engine , near the oil pan, this noise just started happening. It is not an exhaust leak. Also my engine vibrates a lot in idle and even when im stopped at a stop light,in neutral, park it does not vibrate when im driving. when i open the hood i see the engine shaking.There is no engine light. When my rpm is 500-700 it vibrates after that it does not. I got the throttle body cleaned and checked. when im in idle i see the rpm going to up and down like it goes to 500 rpm and then 550 rpm i see the oil pressure gauge moving also when the rpm goes up and down. I dont know whats going on. the truck drives very good, but when im in idle i get engine vibration and a ticking sound. Thank you so much for your help!!
May 19, 2015 at 3:09 PM
