Motor mount torque and repair procedure needed
2014 CHEVROLET SPARK EV
122,000 MILES
SPARKEV
  • 10 POSTS
Car listed above EV model. I've got a worn motor mount and I'm looking for torque specs. Repair procedure would be helpful too.
GM 95024458 "Side mount"
Mar 2, 2020 at 2:26 AM
Here are the engine mount installation instruction in the diagrams below. Check out the diagrams (below). Please let us know if you need anything else to get the problem fixed.
Mar 3, 2020 at 10:32 AM
SPARKEV
  • 10 POSTS
Thanks Ken and Roy. Ken, those diagrams are for the gasoline Spark. I have the EV version, 2014 Spark EV 2LT. I attached a diagram showing the part.
Mar 3, 2020 at 11:58 AM
Hello again.
That mount can be accessed by removing the bolt to the frame. Then you will need to jack up the motor with a block of wood and a floor jack and then release the bolts for the mount.
Mar 3, 2020 at 12:37 PM
Sorry our bad, here is the motor mount replacement instructions for all of the mounts just in case you need them. Check out the diagrams (below). Please let us know if you need anything else to get the problem fixed.
Mar 4, 2020 at 9:40 AM
SPARKEV
  • 10 POSTS
Excellent, thanks!
Mar 4, 2020 at 1:33 PM
Use 2CarPros anytime, we are here to help. Please tell a friend.
Mar 5, 2020 at 9:26 AM
SPARKEV
  • 10 POSTS
Looks like I selected "Spark" instead of "Spark EV" when I submitted the question. Not sure if you can correct that, but it may help people in their search. Thanks again.
Aug 5, 2020 at 10:03 AM
Yes, all the information is the same for the EV.
Aug 5, 2020 at 10:17 AM
SPARKEV
  • 10 POSTS
Point being, when you search for answers here, you need to select a model. There are two options, Spark and Spark EV. I just tried it. I selected Spark EV and this thread is not listed in the results because I mistakenly submitted it has Spark. It should be changed to Spark EV if possible, as it pertains to an electric car not an internal combustion car.
Aug 5, 2020 at 10:42 AM
I will have the site admin update it. Thank you for the concern.
Aug 8, 2020 at 11:42 AM
