alternator issues
1978 CHEVROLET VAN
300,000 MILES • 4.1L • 6 CYL • RWD • MANUAL
SAMUEL HUDSON BAKER
So, i have a Nomad. I am having issues with the electrical system. I have only had it for a few months and have been plagued with dim lights, no turn signals, dead batteries, etc. Currently the alternator and battery are new. Things have been working well since the install until today. Driving with headlights on and heater on i started to get symptoms of bad alternator this morning. Sure enough would not start, once i got to my destination and turned it off. Belt seemed a bit loose, tightened it, got a jump and all seemed well. (figured it was not spinning alternator right) Went to lunch and back, no issues (also no headlights or heater on). Driving home tonight, same symptoms returned (with headlights and heater on), this time the belt was not loose though. I am out of ideas as to why it wont charge suddenly. first time i used the heater was today. Maybe that? Cheap Walmart radio installed a couple of months ago.
Nov 7, 2016 at 6:44 PM
HMAC300
  • 48,601 POSTS
it sounds like you have a parasitic draw on the battery and or a weak battery. have battery checked for condition including load test most places do for free. also check battery terminal ends for cleanliness. see link for how to test for a draw. also if you have glove box, trunk, and under hood lights these are big culprits for a draw. and maybe check your radio install maybe not be done right.
https://www.2carpros.com/articles/car-battery-dead-overnight
Nov 8, 2016 at 6:06 AM
Please check the engine ground strap to the frame, it sounds like the engine is not properly grounded.
Please let me know.
Best, Ken
Nov 13, 2016 at 10:13 AM
