If the cylinder head gasket is not leaking, where is that air coming from? Oil and coolant mixing is by far the least common way a cylinder head gasket will leak because there is so little difference in pressures between the passages for those two systems. Gases in the combustion chamber will be at hundreds of pounds of pressure. It takes a lot for the gasket to seal that.
The chemical test Ken is referring to involves drawing air from the radiator, while the engine is running, through a glass cylinder partially-filled with a special dark blue test fluid. If it turns bright yellow, that is positive for combustion gases sneaking into the cooling system. It doesn't have anything to do with engine oil.
About half of these leaks also let coolant go into the combustion chamber from the vacuum during the intake stroke. That will cause white smoke from the tail pipe. Don't be alarmed if you see steam at the tail pipe, or clear water dripping from the tail pipe or the drain hole in the bottom of the muffler. Water vapor is a byproduct of a properly-working catalytic converter. The clue here is the coolant level will be going down in the reservoir.
Jun 18, 2020 at 2:23 PM
