Reverse lights not working
CHEVROLET VENTURE
INSPECTOR GAJIC
Make: Chevy
Model: Venture
Year; 2000
Mileage: 224000
Engine size: 3.4L
The reverse lights on my van do not work, I replaced the bulbs and checked all fuses, and didn't find any problems there. What other steps do I need to make the repairs needed?
Oct 2, 2007 at 7:46 AM
Put key to On position-remove bulb put test light in the center contact-ground test light-do you have power-if not start at the transmission neutral safety safety switch at reverse contact, got power-check the wire between it and bulb socket.
Got power at the bulb-you lost the ground wire.
Oct 2, 2007 at 10:17 AM
