Neutral saftey switch
CHEVROLET VENTURE
INSPECTOR GAJIC
Make: Chevy
Model: Venture
Year: 2000
Milage:227000
Engine size: 3.4L V6
How do I change Neutral saftey switch on this vehicle and where is it located?
Oct 5, 2007 at 5:37 AM
BMRFIXIT
  • 19,053 POSTS
[quote="inspector gajic"]Make: Chevy
Model: Venture
Year: 2000
Milage:227000
How do I change Neutral saftey switch on this vehicle and where is it located?[/quot
most common place for it is on the tranny wher e the shifter cable conect look for a switch under it
good luck
let us know
Oct 5, 2007 at 9:54 PM
ALLENVAN
Hey i am having trouble with my van, it will not go into gear at all, the shifter just moves up and down with little resistance. What does this Nuetral switch do??? Could that be my problem???
May 13, 2008 at 9:14 AM
BMRFIXIT
  • 19,053 POSTS
Neutral safety switch is to prevent starting will selector in gear
it will start only in park or neutral
you need to check the shifter level and shifter cable
May 13, 2008 at 12:50 PM
ALLENVAN
[quote:b631dadbb3="BMRFIXIT"]Neutral safety switch is to prevent starting will selector in gear
you need to check the shifter level and shifter cable[/quote:b631dadbb3]
Thank you so much, the shifter cable has come off of the trans shifter arm, the problem is the little boot that connects the two of them, it seems like just allittle round piece of rubber, and some of it was on the ground, and the other is up in the cup connector. Now my question is, can i just replace that little boot piece inside there, or do i need to change the whole cable???
YOu have been a great help, thank you again, if you think i can just change the boot, where would i go to get one. Have been online looking with no luck..
AGAIN THANK YOU SO MUCH!!!!
May 13, 2008 at 7:13 PM
BMRFIXIT
  • 19,053 POSTS
check with your local Chevy dealer they should be able to help
https://www.2carpros.com/forum/automotive_pictures/99387_venture_1.jpg
May 13, 2008 at 7:29 PM
