2005 Chevy Venture Replacing Wheel Bearing Hub
2005 CHEVROLET VENTURE
90,000 MILES • 6 CYL • FWD • AUTOMATIC
AUTONUT50
I am replacing wheel bearing hub assembly; I have loosened the hub from steering knuckle, but am not able to remove the hub assembly from the end of the axle. I have used hammer, but will not loosen to slide off.
Any suggestions?
Mar 15, 2010 at 12:15 PM
BLUELIGHTNIN6
  • 16,542 POSTS
have to use front hub spindle remover service tool to push the drive shaft out of the bearing/hub assembly..
Mar 15, 2010 at 4:29 PM
HEYOU100
  • 6 POSTS
I have a 2004 Venture. You'll need a 34mm deep socket to remove the axle nut. once removed, tap the axle back toward the engine a little. Undo the three bolts to the bearing hub and tap (hit, smash) it off with a hammer - couple hits on the left side, couple on the right.
Apr 22, 2010 at 6:58 PM
