2004 Chevy Venture power window switch
2004 CHEVROLET VENTURE
82,000 MILES • 6 CYL • FWD • AUTOMATIC
AHABOSEM
The passenger side power window will only go down and not up. It's currently down and I can't get it up. I was told that I need a switch. Would that be the master switch on the driver's side or the switch on the passenger side or both. Also is this something I can replace myself and where would I find instructions on how to replace it.
Thanks!
Morty
Apr 12, 2010 at 7:34 AM
FACTORYJACK
  • 4,159 POSTS
Assuming it works from neither the left front, or right front switch, it would almost be most likely the passenger window switch, if it is a switch. Do you have a 12 volt test light?, to diagnose and confirm would not be too difficult. You could have faulty(open) wiring that would cause this concern.
Apr 12, 2010 at 10:18 PM
SJLARSON
so, how do i test the circuit, specifically (i have the same issue)
Mar 23, 2012 at 7:55 PM
