firing order?
2004 CHEVROLET VENTURE
116,450 MILES • 6 CYL • FWD • AUTOMATIC
ALLLEE7
So I have a spark plug that is stuck inside the hole. The end snapped off of it where the socket goes on and now there is just park of the metal sticking out. I tried a reverse tap and the tap broke off inside the end of the spark plug. Now what do i do? The spark plug is on the backside of the engine too so there isnt' alot of room to get around i need the firing order.
Feb 28, 2010 at 9:04 AM
DANNY L
  • 5,648 POSTS
Hello, I'm Danny.
Here is the firing order information you've requested. I've attached the 2 pictures below. Hope this helps and thanks for using 2CarPros.
Dec 8, 2020 at 12:56 PM
CHRISWISE1972
need firing order.
Dec 9, 2020 at 8:58 AM (Merged)
MASTERTECHTIM
  • 4,750 POSTS
The firing order for your engine is:
Firing Order 1-2-3-4-5-6
Here are diagrams below to help you see how to route the plug wires.
Check out the diagrams (below)
Cheers
BOB.GATES12
I need the wiring diagram for a 2003 chevy venture 3400 sfi
Hi there and welcome to 2carpros-see below and good luck
https://www.2carpros.com/forum/automotive_pictures/12900_fo34_1.jpg
Dec 9, 2020 at 8:59 AM (Merged)
ALBERT SOENYUN
Misfiring, cross wires, plug wires in order.
Good afternoon.
Do you have the 3.1 or the 3.4? Makes a difference.
Okay, found the cylinder location and the coil wire connections.
FRANCOCO
What is the firing order for this car?
ROCKWOOD84
  • 103 POSTS
can't tell you without knowing what the motor is. but if it is a 3.4 the firing order is 123456 and is sequencial . when you ask for a firing order need to say what motor.....
