Interior Lights
2003 CHEVROLET VENTURE
JD45144
Electrical problem
My van doesn't have interior lights.. all fuses check good
Aug 11, 2010 at 12:44 AM
BLUELIGHTNIN6
  • 16,542 POSTS
make sure the dome light switch is not turned off , if it is on test for power at the switch.It is located in the overhead console
See the diagram below
Aug 11, 2010 at 1:50 AM
ALRACELIS
My chevy venture does not have interior lights. I checked all fuses and the bulbs, but no luck. What should i do next?
Dec 25, 2018 at 9:29 AM (Merged)
HMAC300
  • 48,601 POSTS
have a pro scan for codes it may be a body module problem
LVZ123
I am having a problem with the Interior lights. They stay on when I start the vehicle and while I am driving. They do not shut off like they did before. they use to dim off and now after 5 minutes they shut off.Could it be a door sensor?
DOCFIXIT
  • 18,828 POSTS
Very likely check each one manually operate switch if you get to one that does not turn off that's it. Also belive they are on timer circuit maybe faulty.
ANDY1995
I have a 2004 chevy venture van. last night I was driving up town and my inside lights came and they did not go off so I pushed the switch to turn them off but when I flip it back off the lights still stays on"
HMAC300
  • 48,601 POSTS
have it scanned as it may be a body module problem also check your door switchs
