The car hesitates when I move from the brake to the accelerator just before coming to a complete stop. I've checked the fuel pressure and it was within spec. I've also replaced the IAC valve to no avail. Not sure what to try next. No problems when accelerating any time other than just before the car comes to a complete stop. Service engine light is on with a Camshaft Position Sensor out of range code. I've actually replaced this sensor but the light is still on. I'm guessing it is either the wiring to the sensor, the connector or the PCM, but I am assuming that this is unrelated to the performance problems since car/engine sound fine other than this one issue (please let me know if you disagree). Any ideas?
Apr 29, 2009 at 9:17 PM
