2003 Chevy Venture Alternator????
2003 CHEVROLET VENTURE
120,000 MILES • 4 CYL • FWD • AUTOMATIC
DPOSS20406
My husband is trying to replace the alternator on our 2003 venture van. Its in a really ackward spot and hard to get to. We have been told by other people to remove motor mounts and roll motor forward but we do not know exactly how to do this or if we even should. Need some help PLEASE!!!
Nov 29, 2008 at 11:02 AM
IMPALASS
  • 3,112 POSTS
Hello I have attached the info on rotating the engine and changing the alternator. Just be careful ensure things are braced and secured before sticking body parts in areas that can be pinched. Safety first! Rotating the Engine for Service Access Tools Required J 41131 Engine Tilt Strap Remove the throttle body air inlet duct. Set the park brake. Shift the transaxle into Neutral. Remove the engine mount strut bolts. Swing the engine mount struts aside.
https://www.2carpros.com/forum/automotive_pictures/248015_1_43.gif
Install the J 41131. Pull on the engine in order to rotate the engine forward. Tighten the J 41131. REMOVAL PROCEDURE Remove the battery ground (negative) cable from the battery. Rotate and secure the engine forward to access rear generator bolts. Refer to Rotating the Engine for Service Access in Engine-3.4L.
https://www.2carpros.com/forum/automotive_pictures/248015_2_52.gif
Remove the generator B+ terminal nut. Remove the generator B+ lead. Remove the generator electrical connector. Remove the drive belt from the generator.
https://www.2carpros.com/forum/automotive_pictures/248015_3_35.gif
Remove the generator front bolt.
https://www.2carpros.com/forum/automotive_pictures/248015_4_25.gif
Remove the generator rear bolts.
https://www.2carpros.com/forum/automotive_pictures/248015_5_19.gif
Remove the generator from the generator bracket and position the generator above the drive axle. Remove the drive belt tensioner. Remove the generator bracket. Remove the power steering pipes from the power steering pipe retainer. Remove the fuel pressure test port (schrader valve) cap from the fuel injector rail. Remove the power steering pump and reposition the power steering pump in front of the timing chain cover in order to provide access for the generator. IMPORTANT: Do not disconnect the power steering pipes from the power steering pump. Remove electrical harness from retainer on right fender well and position aside. Remove the generator from the vehicle. INSTALLATION PROCEDURE Install the generator to the vehicle and position the generator above the drive axle. Install electrical harness to retainer on right fender well. Install the power steering pump to the engine. Install the fuel pressure test port (schrader valve) cap to the fuel injector rail. Install the power steering pipes from the power steering pipe retainer. Install the generator bracket. Install the drive belt tensioner.
https://www.2carpros.com/forum/automotive_pictures/248015_5_20.gif
Install the generator to the generator bracket and position the generator above the drive axle. Install the drive belt tensioner. Install the generator to the generator bracket.
https://www.2carpros.com/forum/automotive_pictures/248015_3_36.gif
Install the generator front bolt.
https://www.2carpros.com/forum/automotive_pictures/248015_4_26.gif
Install the generator rear bolts. NOTE: Refer to Fastener Notice in Service Precautions. Tighten Tighten the generator bolts to 50 N.m (37 lb ft) . Install the drive belt.
https://www.2carpros.com/forum/automotive_pictures/248015_2_53.gif
Install the generator electrical connector. Install the generator B+ lead. Install the generator B+ terminal nut. Tighten Tighten the generator B+ terminal nut to 13 N.m (115 lb in) . Rotate the engine rearward and install the engine mount strut bracket bolts. Refer to Rotating the Engine for Service Access in Engine -3.4L. Install the battery ground (negative) cable to the battery.
Nov 29, 2008 at 11:24 AM
IMPALASS
  • 3,112 POSTS
Hello Just as a note after I had sent you the information I did some other looking. You may have some recalls on your vehicle. The dealer may fix these for free. Please contact the dealer service department, give them the VIN number of your car and have them check on these to see if they apply to you.
https://www.2carpros.com/forum/automotive_pictures/248015_Picture7_9.jpg
https://www.2carpros.com/forum/automotive_pictures/248015_Picture8_8.jpg
Nov 29, 2008 at 8:32 PM
