2002 Chevy Venture Using Oil
2002 CHEVROLET VENTURE
90,000 MILES • 6 CYL • FWD • AUTOMATIC
RAMCGUIRE56
My venture has been using more and more oil. It now requires a quart about every 300 miles. Is the engine due for a major overhaul or is there something I can do to reduce usage?
Feb 28, 2009 at 7:56 AM
MMPRINCE4000
  • 8,548 POSTS
It is either leaking it or burning it. Check the engine for leaks first, which is more common that major engine problems.
If no leaks, then it is usually valve seals and/or piston rings.
It is probably more practical to replace the engine with a low mile used on rather than a rebuilt.
But check for leaks first, it could be a simple repair.
Feb 28, 2009 at 8:10 AM
