had a fuel pump go bad in van when I changed it out the plug was burnt now that it is back together it will not start !! have checked the relay switch and have checked all terminals to make sure they have power they do . took the fuel tank back off and found that the grey wire in the harness that goes to fuel pump does not have any power going to it from the plug to engine I have by passed the computer and still no power need to find out the wiring diagram is or what the problem may be is the computer shot or when the plug burnt did it short the wire and where does the wire go ? please help !!!!!! Thank You
Jul 17, 2010 at 7:10 PM
