2001 Chevy Venture Transmission won't shift, black/brown le
2001 CHEVROLET VENTURE
93,000 MILES • 6 CYL • 2WD • AUTOMATIC
GEOFFDADDY
My Chevy Venture won't move at all, this was a gradulal problem that started with hesitation oin shifting and trouble pulling from a stop or going uphill. There is a visible leak around the radiator area and the fluid is watery, and black/brown. The "service engine" light is steady. What is wrong? Is the whole transmission gone.
Dec 2, 2009 at 11:40 AM
DOCFIXIT
  • 18,828 POSTS
Hi
Watery black/brown is a death note means clutches have burnt. So trans is toast. Drop pan if full of sluge and metal shavings then it's over.
Thanks for donate
Dec 2, 2009 at 12:28 PM
GEOFFDADDY
this is the problem even if the leak is near the radiator?
Dec 2, 2009 at 12:30 PM
DOCFIXIT
  • 18,828 POSTS
Leak is not going to keep trans from shifting have codes read and sure it is a trans related code.
Dec 2, 2009 at 12:37 PM
