Electrical problem
2001 Chevy Venture 6 cyl Front Wheel Drive Automatic
OK let me say first that I havent done alot of troubleshooting in this issue yet but I was wanting a second opinion before I spent alot of time in the wrong area.
I have a 2001 Chevy Venture that belongs to my sister. Last week the power windows,power locks,instrument cluster(Lights and Gauges), and the interior lights quit working. Then a day later the radio went into lockout. On originally looking it over I noticed that the batter was leaking battery acid so we replaced it and cleaned all connections. When we started the van again the radio worked for a few seconds and then went into lockout again. At this time I tried to plug in my scan tool to see if I could pull any codes out of the PCM or BCM. To my surprise my scan tool would not power up. I checked for voltage on the DLC and have less than 2 volts instead of battery voltage. Also I can not find a ground on the DLC. I am thinking that I might have either a bad ground. bad fuseable link? Can the Body Contol Module create a problem with the DLC? I can give more information as I start to test some things out but I was looking for a little input or thought maybe someone has run across this issue before?
Thanks,
Bill
Thanks,
Bill
Oct 27, 2008 at 7:09 PM
