I have an 01 Venture that I just got (great purchase...chuckle chuckle). So, I have a problems with the temperature gauge bouncing all over without heat and on other days it works. Apparently this is pretty common and there does not appear to be a solution. So, I was going to "burp" the engine this weekend to see if that would help and now I find that the coolant leaks out almost as fast as I put it in. I am not sure where, but it is leaking out underneath from around the transmission pan. Any ideas? I am thinking head gasket...yikes. Any help would be appreciated as I am not all that mechanical...Should I try a sealant to see if that works?
Mar 28, 2009 at 12:30 PM
