[quote:76bf461295="jnice13"]Engine Cooling problem
2000 Chevy Venture 6 cyl Front Wheel Drive Automatic 110860 miles
my mechanic wants to charge me $700.00 to replace my intake manifold gasket and my water pump. He says that is what is causing my antifreeze leak i dont trust him. does this sound correct?[/quote:76bf461295]
Wow, sounds cheap. I just had my intake manifold gasket replaced for $1k at the dealer (gasket only).
Yes, this can cause coolant to leak into the crankcase (check your oil and see if it is a 'chocolate milk' like consistency or perhaps frothy or foamy on top. This indicates coolant in the crankcase and suggests a head gasket or intake manifold gasket problem. I have been told that the GM V-6 3.4 liter engine has problems with intake manifold gaskets.
Apr 29, 2009 at 9:47 PM
