2000 Chevy Venture code p0306
2000 CHEVROLET VENTURE
208,000 MILES • 6 CYL • FWD • AUTOMATIC
LISAW22949
I have a 2000 venture van under heavy acceleration it starts to surge and engine light flashes. When going up hill lugged down you get a clunk. had head gaskets replaced at around 200,000km.Checked plug ok checked coil tower for corossion ok. Any ideas?
Feb 10, 2008 at 7:10 AM
BLACKOP555
  • 10,386 POSTS
P0306 is missfire on cylinder 6 and i belive it could be caused due to a dirty MAF sensor, clean it and see if it goes away.
Feb 10, 2008 at 7:38 AM
LISAW22949
It was a rotten plug wire. It wasn't leaking externally?The core was rotten. How are you suspose to clean a MAF sensor when any cleaner will remove the protective coating from the wire?
Feb 13, 2008 at 3:56 PM
BLACKOP555
  • 10,386 POSTS
rotted core on the wire, thats a new one.
MAF sensors can be cleaned with brake cleaner, or QD contact cleaner, its recommended, it doesnt remove the protective coating, just spray it on.
Feb 13, 2008 at 4:29 PM
